configure lldp ports system-capabilities
configure lldp ports [all | port_list] [advertise | no-advertise] system-capabilities
Description
Configures the LLDP port to advertise or not to advertise its system capabilities to its neighbors.
Syntax Description
all Specifies all ports on the switch.
port_list Specifies one or more ports or slots and ports.
advertise Specifies to send the information to neighbors.
no-advertise Specifies not to send the information to neighbors.
Default
No advertise.
Usage Guidelines
When at least one VLAN exists with more than two ports, bridging is sent to enabled.
When at least one VLAN on the switch has IP forwarding enabled, the system automatically sets the router bit.
The following command configures all ports to advertise system capability information to neighbors:
configure lldp ports all advertise system-capabilities
Platform Availability
